Syntax @SecondOrderConformal(,,,,,,,) @SecondOrderConformal(,,,,,,,,) Arguments ,,,,,,, Coefficients of the 2D conformal transformation. The transformation results in the x and y coordinates being modified by: x' = C + E(x-A) - F(y-B) + G((y-B)^2 - (x-A)^2) - 2H(x-A)(y-B) y' = D + E(y-B) + F(x-A) + H((y-B)^2 - (x-A)^2) + 2G(x-A)(y-B) Range: Real number ,,,,,,,,,,, Coefficients of the 3D conformal transformation. The transformation results in the x and y coordinates being modified identical to above, and in addition, the coordinates being modified by: z' = z + I Range: Real number Description This function performs a second-order conformal transformation to the feature coordinates upon which it is invoked. Depending on the input geometry and input parameters, a 2D or 3D transformation is performed. This transformation is non-linear, and thus does not preserves the shape of geometries. However, we preserve the integrity of the input geometry (i.e. input lines will be kept as lines with modified coordinates with respect to the transformation). If the parameters G and H are zero, then this function performs an equivalent affine (linear) transformation. Using @Affine in this case will achieve the same result. Note: This operation is not supported for 3D features.
