Syntax @ResolveRasterPalettes() Description The @ResolveRasterPalettes function is used to ensure that the source band type is continuous. If the source is classified, it will be resolved to be continuous without changing the original data source. If the source is continuous, nothing will be done and the data will be passed straight through. This function supports sub-selection of raster bands and palettes.
