Syntax @RemovePointCloudComponents([,]+) Arguments Specifies whether components will be removed or kept. When set to REMOVE, the specified components will be removed. When set to KEEP, the specified components be kept and all other components will be removed. Range: REMOVE | KEEP Names of the components to remove or keep. Description The @RemovePointCloudComponents function is used to remove unwanted components from a point cloud. Input features must contain point cloud geometries only.
