Syntax FACTORY_DEF RasterSegmentationFactory [FACTORY_NAME ] [INPUT FEATURE_TYPE [ ]* []*]* [POLYGON_MODE (NODATA|UNIQUE)] [POLYGON_LABEL_ATTRIBUTE ] [EXTRACT_NODATA (yes|no)] [PRESERVE_ATTRIBUTES (yes|no)] [OUTPUT POLYGONS FEATURE_TYPE [ ]* []*]* Overview This factory creates polygons from input rasters. The POLYGON_MODE option specifies how polygon boundaries are determined. The factory supports the NODATA and UNIQUE modes. See the Polygon Mode section for more details. The POLYGON_LABEL_ATTRIBUTE clause specifies the name of an attribute that will be created on every output feature describing the type of the polygon. The value of this attribute depends on what mode the factory is in. See the Polygon Mode section for more details. The PRESERVE_ATTRIBUTES clause specifies whether the output vector features should retain attributes from the input raster feature. This factory accepts only features that have raster geometry. This factory supports sub-selection of raster bands. Polygon Mode NODATA In this mode, the extracted polygons divide the raster into regions of nodata and data. A cell is considered to be nodata when, for each selected band, the value for that cell is equal to that band's nodata value. If any cell value is not equal to that band's nodata value, the cell will be considered data. The POLYGON_LABEL_ATTRIBUTE value will be set to "data" for polygons representing a region of data, and "nodata" for polygons representing a region of nodata. In this mode, all selected bands are required to have a nodata value. UNIQUE In this mode, a polygon is created for each contiguous area of pixels with the same value. Nodata polygons will only be extracted if EXTRACT_NODATA is set to Yes. The POLYGON_LABEL_ATTRIBUTE value will be set to a comma-separated list of the band values covered by that polygon. For example, the label for a raster with three bands might be something like 64,128,255. Output Tags The RasterSegmentationFactory supports the following output tag. POLYGONS Output polygons created from the input raster(s).
