Syntax @RasterPaletteAttributes(, ) Arguments In ADD mode, the function will create a palette from and add it to selected bands. In EXTRACT mode, the function will take an existing palette and write it to . Range: (ADD|EXTRACT) The attribute from which the palette will be read, or to which the palette will be written. Range: String Description The @RasterPaletteAttributes function is used to convert between palettes and attributes. In ADD mode, the function will create a palette from an attribute, and add this palette to all selected bands. Selected bands are required to have an interpretation of UINT8, UINT16, or UINT32. Note: Palette entries will be discarded if they do not fit within the interpretation of a selected band. For example, when adding a palette to a UINT8 band, all keys that are greater than 255 will be dropped. In EXTRACT mode, the function will create a string representation of an existing palette and save it to an attribute. In this mode, exactly one palette must be selected on the raster. Note: This function may be used in combination with @File to read palettes from files or write palettes to files. For example, one could use @File to read a file into an attribute, then use @RasterPaletteAttributes to create a palette from the attribute. See the Palette Format section for a description of the format of palette attributes. This function supports raster band and palette selection. @SelectRaster can be used to modify selection. Palette Format ~~~~~~~~~~~~~~ The general format of a palette attribute is as follows: [] ... The first line of the palette must contain the value interpretation. Valid values for the value interpretation are RGBA32, RGB24, RGBA64, RGB48, GRAY8, GRAY16, and STRING. When an interpretation of STRING is specified, the first line may optionally specify the maximum string length of the palette values. This value must be a positive integer. If no string length is explicitly specified, a default of 32 will be assumed. RGBA and RGB palette values consist of comma-delimited strings of integers between 0 and the maximum value of the datatype. For example, a valid RGBA32 value would 64,128,255,255, and a valid RGB48 value would be 16384,32768,65535. GRAY palette values consist of a single integer between 0 and the maximum value of the datatype. STRING palette values may consist of any arbitrary text, except for the newline character. All lines after the first are key-value pairs. Palette keys must be organized in ascending order, but they are not required to be contiguous. For example, you can have palette entries for keys 0, 2, and 4, but not 1 or 3. All missing palette entries are assumed to look up to 0 or an equivalent value, such as 0,0,0 for RGB or an empty string for string palettes. Palette Examples ~~~~~~~~~~~~~~~~ Here is an example of a color palette: RGB24 0 0,49,190 1 50,255,50 2 172,0,255 3 255,0,0 And here is an example of a string palette: STRING 10 0 Water 1 Forest 2 Commercial 3 Urban
