Syntax FACTORY_DEF RasterClippingFactory [FACTORY_NAME ] [INPUT CLIPPER FEATURE_TYPE [ ]* []*] [INPUT CLIPPEE FEATURE_TYPE [ ]* []*] [MULTICLIP (YES|NO|CLIPPERS_FIRST) [MERGE_CLIPPER_ATTRIBUTES (YES|NO) [CLIPPER_ATTR_PREFIX ] [PRESERVE_CLIPPEE_EXTENTS (YES|NO)] [GROUP_BY []+] [OUTPUT (CLIPPED_INSIDE|CLIPPED_OUTSIDE| INSIDE|OUTSIDE|REJECTED) FEATURE_TYPE [ ]* []*]* Overview This factory is used to perform a geometric clipping operation on input raster features. It takes two types of features identified by the CLIPPER and CLIPPEE input tags. Clipping features are identified by the tag CLIPPER. These features identify the area against which all CLIPPEE features are processed. Clippers can be polygon, donut, or aggregate features. Clippees must have raster geometry; they are unaffected by raster band and/or palette subselection. Clipping will operate such that for each clippee, the following possible output will be generated: One CLIPPED_INSIDE feature for every clipper that intersects the clippee, and one CLIPPED_OUTSIDE feature One INSIDE feature One OUTSIDE feature Clippees will be output untouched through the OUTSIDE port if they are disjoint from all clippers. Clippees will be output untouched through the INSIDE port if they are contained in, covered by, or equal to any of the clippers. Otherwise, each clipper that intersects the clippee will produce output through the CLIPPED_INSIDE port. If PRESERVE_CLIPPEE_EXTENTS is set to "no", the extents of this raster will be equal to the bounding box of the portion of the clipper within the clippee. Otherwise, if PRESERVE_CLIPPEE_EXTENTS is set to "yes", the extents will be identical to those of the clippee. The remaining areas of the clippee that are disjoint from all clippers will be output through the CLIPPED_OUTSIDE port. The extents of this raster will be identical to those of the clippee. The MULTICLIP option has the same effect as the MUTICLIP option of the ClippingFactory. Please consult the ClippingFactory documentation for more information on this keyword. If MERGE_CLIPPER_ATTRIBUTES is specified, then whenever a clippee is found to be inside or clipped inside a clipper, the attributes of the clipper will be copied to the inside parts of the output features. The CLIPPER_ATTR_PREFIX directive specifies a string prefix to be added to the attributes of a CLIPPER that are copied to a clippee. If attributes of the same name already exist on the clippee, they will be overridden. If this prefix is not specified or is empty, the attributes will still be copied to the output features, but they will not overwrite any existing attributes of the same name. If the GROUP_BY clause is given, then each clippee will only be clipped by clippers that contain the same values as itself in the attributes specified by this clause. Output Tags The RasterClippingFactory supports the following output tags. CLIPPED_INSIDE Areas of a clippee that intersect a clipper. CLIPPED_OUTSIDE Areas of a clippee that do not intersect any clipper. INSIDE Clippees that are contained in, covered by, or equal to a clipper. OUTSIDE Clippees that are disjoint from all clippers. REJECTED Extraneous clippers that are received by the factory when MULTICLIP is not set to YES, as well as any other invalid features (i.e. non-area clippers)
