Syntax FACTORY_DEF PointCloudCombinerFactory [FACTORY_NAME ] [INPUT FEATURE_TYPE [ ]* []*]* [COUNT_ATTRIBUTE ]* [ACCUMULATE_ATTRIBUTES (yes|no|none|all|one)] [LIST_NAME {}] [GROUP_BY []+]* [OUTPUT MERGED FEATURE_TYPE [ ]* []*]* Overview This factory is used to merge a collection of point cloud features into a single point cloud feature. The points in the output cloud will have the union of the point components of the merged point clouds. The input features may be partitioned into groups based on attribute values using the GROUP_BY clause and one point cloud feature is produced for each group. If the GROUP_BY clause is not specified, then all input features will be processed together and a single point cloud feature will be produced. If the optional COUNT_ATTRIBUTE clause is given, a new attribute will be created on every output feature, containing the number of input features that were combined to form the output. If grouped, the output feature's count attribute will have the number of input features that merged within its group. If yes or all is specified for the ACCUMULATE_ATTRIBUTES clause, the attributes of each input feature are merged onto the feature being output. If grouped, the attributes of each input feature within a group are merged onto the group's output feature. If no or none is specified for the clause, no user attributes will be carried across from the input features to the output features. If one is specified for the clause, user attributes only from one input feature will be on the output feature. The optional LIST_NAME clause is used to associate attributes with incoming feature. When the output feature is created, all attributes of each feature joining the output are added as members of the specified attribute list. The index in the list corresponds to the index of the feature's geometry in the aggregate. Output Tags The PointCloudCombinerFactory supports the following output tag. MERGED The output feature created by merging the input features.
