Syntax @OrderRasterBands() Arguments A space-delimited string that specifies the desired order of the bands. Range: String Description The @OrderRasterBands function is used to change the order of bands in a raster. The parameter is a list of band indices, separated by spaces, which specifies the desired order of the bands. Indices are zero-based, so the first band is at index 0. Bands in the original raster that are not specified in the string will be appended after all the specified bands, in their original order. Note: Bands may not be included in the list more than once. For example, given an RGBA input raster with four bands and a band list of "3 0 2", the resulting raster would have bands ARBG. Input features must contain raster geometries only.
