Syntax @GeoreferenceRaster(POINT_AND_ANGLE, , , , , ) @GeoreferenceRaster(EXTENTS, , , , , , , , ) @GeoreferenceRaster(CELL_SIZE_UL, , , , ) @GeoreferenceRaster(EXTENT_UL, , , , ) @GeoreferenceRaster(EXTENT, , , , [, ]) Arguments Specifies whether to accept spacing and rotation input or extent input. POINT_AND_ANGLE implies the upper left corner coordinates, the spacing, and the rotation are provided. EXTENTS implies the upper left, upper right, lower right, and lower left corner coordinates are provided. Range: (POINT_AND_ANGLE|EXTENTS|CELL_SIZE_UL|EXTENT_UL|EXTENT) The upper left X coordinate of a raster Range: Reals The horizontal length of a cell Range: Reals The vertical length of a cell Range: Reals The rotation of a raster, in degrees Range: Reals The upper right X coordinate of a raster Range: Reals The upper right Y coordinate of a raster Range: Reals The bottom right X coordinate of a raster Range: Reals The bottom right Y coordinate of a raster Range: Reals The bottom left Y coordinate of a raster Range: Reals The bottom left Y coordinate of a raster Range: Reals Description The @GeoreferenceRaster function is used to georeference rasters. If the source raster is already georeferenced, this function will overwrite the previous georeference settings with the new ones. When using POINT_AND_ANGLE, the raster's origin is set to the input upper left coordinate and its spacing and rotation are set to the input spacing and rotation; no calculations are done on the input data. When using EXTENTS, all four input coordinates are validated to be unique, to form a rectangle which can be rotated, and to be clockwise. The rotation and spacing are then calculated from these coordinates. The origin of the raster is set to the input upper left coordinate. Input features must contain raster geometries only. TO BE RESOLVED CELL_SIZE_UL, EXTENT_UL, EXTENT arguments added to Syntax section above, but not documented.
