Syntax @GeneratePoint([,,]) Arguments The name of the attribute that will be set to the the x coordinate value of the generated point. Range: Attribute Name The name of the attribute that will be set to the the y coordinate value of the generated point. Range: Attribute Name The name of the attribute that will be set to the the z coordinate value of the generated point. Range: Attribute Name Description This function generates a point inside a polygon, donut polygon, or 3D Face feature. The generated point is added to the feature's in-memory representation. If no attribute names are provided and the function is called with no parameters, the feature then becomes a point-in-polygon (PIP) feature. When generating a point for a 3D feature, the z coordinate is set to the average Z value of the input feature. If attribute names are provided, the feature's geometry does not change and instead the x, y, and z coordinates of the generated point are added as attributes to the feature. This function can be used when translating data from a model where polygons are directly attached, to a model where polygonal areas are implied by boundary lines, and the attribution for each area is attached to a point within that area. If the input feature is not a polygon, donut polygon, or 3D face, it is returned by the function unchanged. If the FME_GEOMETRY_HANDLING directive is set to "yes" in the mapping file, ellipses are regarded as polygons; they are otherwise regarded as points.
