Syntax @ExtractPointCloudProperties( , , [, [, ]]) @ExtractPointCloudProperties( V2, , , , [, ]) @ExtractPointCloudProperties( MODIFICATION_PROPERTIES) Arguments The prefix to add to attributes related to point cloud components. Range: String A space-delimited list of component names. An attribute indicating whether the component exists in the point cloud will be added to the feature for each component in the list. A space-delimited list of component names. Attributes containing component properties will be added to the feature for each component in the list. A space-delimited list of component names. Attributes containing the minimum and maximum values of the component will be added to the feature for each component in the list. Whether to update the extents (x, y, z) of the point cloud. Range: UpdateExtents | DoNotUpdateExtents Whether to normalize extracted color values. Range: NormalizeColor | DoNotNormalizeColor Description The @ExtractPointCloudProperties function is used to expose the properties of a point cloud as attributes on the feature. In the "normal" modes (i.e. "V1" or "V2"), the following attributes will always be added to the feature: _num_points For the "V1" version of this function (i.e. it does not start with the "V2" parameter), the following additional attributes will always be added: _min_x _min_y _min_z _max_x _max_y For each attribute listed in , a boolean attribute with the name _ will be added to the feature with a value of TRUE if component exists in the point cloud and FALSE if it does not exist. For example, if the point cloud contains a classification component, the _classification attribute will be added to the output feature with a value of TRUE. If the point cloud does not contain a classification component, the _classification attribute will be added to the output feature with a value of FALSE. Note that for all of the above attributes, if a value was specified for , then this will be prepended to the name of the attribute. For example, with an attribute prefix of "_pc", the attribute _pc_classification would be added. For each attribute in the , the following attributes will be added to the feature: __type __scale (numeric components only) __offset (numeric components only) __encoding (string components only) For each attribute listed in , a pair of the following attributes will be added to the feature. The value of the _min attributes will be the minimum value for that component in the cloud. The value of the _max_ attributes will be the maximum value for that component in the cloud. The prefix specified in the Component Attribute Prefix parameter will be inserted between the _min_ and the component name. If the specified component does not exist in the cloud, the attribute will not be output. _min_ _max_ The parameter controls whether the extents of the point cloud will be updated to reflect the true values in the point cloud. That is, the extents of a point cloud may change after certain operations (e.g. clipping). When this happens, the extents are typically set to an approximation of the true bounds (e.g. when clipping, the output point cloud bounds are equal to the intersection of the input point cloud bounds and the clipper bounds). When this option is set to UpdateExtents, all the points of the point cloud will be read, and the point cloud extents will be updated to their exact values. The parameter specifies whether extracted color values should be normalized (i.e. scaled to the range [0,1]). Valid values are NormalizeColor and DoNotNormalizeColor. In "MODIFICATION_PROPERTIES" mode, none of the above attributes are added. Instead, only the following attributes are added: _source_format _source_dataset _modified
