Syntax FACTORY_DEF DatabaseUpdaterFactory [FACTORY_NAME ] [INSERT FEATURE_TYPE [ ]* []*]* [UPDATE FEATURE_TYPE [ ]* []*]* [DELETE FEATURE_TYPE [ ]* []*]* DBUPDATER_FORMAT_SHORT_NAME DBUPDATER_DATASET DBUPDATER_CONNECTION_PARAMS DBUPDATER_TABLE [DBUPDATER_UPDATE_COLUMNS ] [DBUPDATER_KEY_COLUMNS |DBUPDATER_WHERE_CLAUSE ] Overview This factory performs an update, delete, or insert with an FME writer for each feature it receives via its three corresponding input ports. There is no output INITIATOR port because writers tend to de-const and mangle features (and don't want to incur overhead of copying features if not needed). Features that have an fme_where or fme_db_operation attributes are considered to be malformed and will result in an error. One, and only one, of DBUPDATER_KEY_COLUMNS and DBUPDATER_WHERE_CLAUSE should be specified. DBUPDATER_WHERE_CLAUSE is the only directive that is re-evaluated for each feature. *** Might be able to specify neither if only doing INSERTs. Writer Specification ~~~~~~~~~~~~~~~~~~~~ DBUPDATER_FORMAT_SHORT_NAME Type of writer that should be instantiated. DBUPDATER_DATASET WWJD encoded dataset. DBUPDATER_CONNECTION_PARAMS Comma separated list of WWJD encoded writer directive names and values required to establish a connection with the specified format. DBUPDATER_TABLE Table that updates/deletes/inserts will be performed against. DBUPDATER_UPDATE_COLUMNS Comma separated list of WWJD encoded column names. Only these columns will be updated. Any of the listed columns not present on an input feature will be updated to null. If no columns are specified, all columns will be updated. DBUPDATER_KEY_COLUMNS Comma separated list of WWJD encoded column names. These will be used to find matching records for UPDATE and DELETE features. May not be used in conjunction with WHERE_CLAUSE. DBUPDATER_WHERE_CLAUSE Where clause used to find matching records for UPDATE and DELETE features. Will be evaluated on a per-feature basis to allow for attribute substitution. May not be used in conjunction with KEY_COLUMNS.
