Syntax @CalculatePointCloudStatistics( [, [, [, [, [, [, [,]]]]]]]) Arguments <[statistic] component list> A space-delimited list specifying the components for which each statistic will be calculated. Description The @CalculatePointCloudStatistics function is used to calculate statistics on point cloud components. The following statistics may be calculated: - Minimum: The numerical minimum for numeric components, or the lexical minimum for string components. - Maximum: The numerical maximum for numeric components, or the lexical maximum for string components. - Range: The maximum minus the minimum. Undefined for string components. - Mean: The average value, calculated as the sum of values divided by the number of points. Undefined for string components. - Standard Deviation: The standard deviation as measured by the "nonbiased" or "n-1" method. Undefined for string components. - Sum: The sum of all values. Undefined for string components. - Median: The middle value when the values are listed in order if the number of points is odd, or the average of the two middle values if the number of points is even. For string components, the first middle value is always used. - Mode: The most frequent of all the values. If the dataset is bimodal (two or more values occur with the highest frequency) one of the values will be returned randomly. Statistics will be stored as attributes on the feature. Attributes will be named ".", where statistic is one of the following: min, max, range, mean, stdev, sum, median, mode For example, if median was calculated for component "z", then an attribute named "z.median" would be added to the feature. Input features must contain point cloud geometries only.
