Syntax @AddRasterBand(, [, ) Arguments The desired interpretation for the added band, including data type and bit depth. Range: (RED8|RED16|GREEN8|GREEN16|BLUE8|BLUE16|ALPHA8|ALPHA16|GRAY8|GRAY16| INT8|INT16|INT32|INT64|UINT8|UINT16|UINT32|UINT64| REAL32|REAL64) The value that will be used for all cells in the added band. Range: Numeric The nodata value for the band. If left blank, the band will not be given a nodata value. Range: Numeric Description The @AddRasterBand function is used to add a new band to a raster. The added band will have the same value in all cells. Furthermore, the added band will have the same raster-level properties as other bands in the raster (i.e. number of rows/columns, cell spacing, cell origin, etc.). For example, if you had a raster with RGB bands, but you wanted to write the raster as RGBA, you could use this function to add an Alpha band to the raster. The parameter specifies the desired interpretation for the added band. The parameter sets the value that will be used for all cells in the added band. The parameter sets the band's nodata value. If a nodata value is not desired, this parameter may be left blank. Input features must contain raster geometries only.
