Editing Breakpoint Parameters
By default, the Feature Inspector stops at every breakpoint that you define but you can also set inspection parameters so it will stop only when certain conditions are met.
To display the Breakpoint Parameters dialog, right-click on a defined breakpoint and select Edit Breakpoint:
This is the default name that the Feature Inspector assigns to the breakpoint. You can rename any breakpoint.
Check this box to define test clauses for the breakpoint.
The Value columns may be a literal constant, an attribute name preceded by the value-of operator (&), or an attribute value function. If it is an attribute value function, the function will be executed on the current feature and the result will be used for the test.
The operands can consist of:
- An ampersand followed by the name of a feature attribute: this takes the "value-of" the attribute and uses that as the operand for the test: &<attribute name>
You can pick the attribute name from the pull-down list in the grid, or you can type it with the leading &.
- Any FME function:
@FunctionName(argument1,argument2,...)
The function must be typed in directly into the grid, and must follow the FME syntax for functions. See FME Functions and Factories to see a complete list of functions that can be called.
- Any constant value: anything
not starting with an ampersand (&) or at-sign (@) is considered to
be a constant:
anyConstant
You can type the constant in the Test Clause grid.
The grid dialog for the Tester makes it easy to specify any of the above inputs to a test or set of tests.
The Operator column is one of <, >, =, ==, !=, >=, or <=.
The Pass Criteria defines how multiple clauses are interpreted in the final classification of the incoming feature.
You can choose one of three test scenarios:
Scenario | Pass Criteria | Description |
One test is required for the input feature to be classified as PASSED. | One Test (OR) | In this case, as long as one of the test clauses is true, then the feature is PASSED. This is an OR test (test1 OR test2 OR test3). If any one is true, then the result is true. |
All tests are required for the input feature to be classified as PASSED. | All Tests (AND) |
This is stricter than One Test (OR) because all tests must pass in order for the result to be true (test1 AND test2 AND test3). |
Create your own test expression. This is useful when you need fine-grained control over when you want the Feature Inspector to stop. |
Composite Test |
If, for example, you want to check whether the value of an attribute is between 5 and 10, or equals 99, you can set up three test expressions: Clause 1 : x > 5 Clause 2 : x < 10 Clause 3 : x = 99 (where x is the selected attribute in the Left Value field):
To correctly get the desired results, you require that clause 1 AND clause 2 be true (between 5 and 10), OR clause 3 is true (equals 99). In this case, choosing One Test or All Tests modes will not satisfy the test requirement. You can, however, choose Composite Test and enter the following expression in the Test Expression field: ((1 AND 2) OR 3) The numbers above correspond to the test clauses defined in the Test Clauses table. When read, the composite expression above states that Clause 1 AND Clause 2 must be satisfied, OR Clause 3 must be satisfied. |
By default, the Comparison Mode is set to Automatic (compare as numbers if possible).This means the Tester will first try to convert the operands to numbers. If it is successful, it will compare them as numbers. If it is still not successful, it will treat operands as strings.
Alphanumeric Strings: Say you have a string that is labeled "4E5". If you choose Automatic (compare as numbers if possible), it is possible that it will be treated as a number. If you want it treated as a text string, set the Comparison Mode to String (always compare as text strings) – this ensures that the Tester will always treat the operands as strings, and will compare them as strings.
- Always
- A hit is registered every time a condition is met. Enter a number in the text box, and the Feature Inspector will stop only when the hit count is equal to, less than, greater than, or a multiple of that number.
The current hit count is shown on the right.
Related Topics
Tags inspection point
