FME 2016 Workbench Keyboard Shortcuts
Note: For a printable version of this page, click here.
General Viewing
New (create a new workspace) | Ctrl+n |
Generate workspace | Ctrl+g |
Open | Ctrl+o |
Exit (workbench) | Ctrl+q |
Close (workspace) | Ctrl+w |
Change to next tab | Ctrl+Tab |
Change to previous tab | Ctrl+Shift+Tab |
Select tab number | Ctrl+number_key |
Close current tab | Ctrl+F4 |
Open containing folder | Ctrl+o |
Maximize canvas to current window size | Shift+F11 |
Maximize canvas to full screen | F11 |
Zoom-in | Ctrl+ |
Zoom-out | Ctrl- |
Zoom 100% | Ctrl+0 |
Zoom in and out | Ctrl+scroll wheel |
Zoom to next/previous bookmark |
Space/Ctrl+Space Note: Show Bookmark Navigator must be enabled on the toolbar. |
Pan | Click scroll wheel (or middle mouse button) and drag cursor. |
Return cursor to action arrow. | Right-click anywhere on the canvas. |
Search:
Ctrl+f F3 |
General Editing
Cut | Ctrl+x |
Copy | Ctrl+c |
Paste | Ctrl+v |
Redo | Ctrl+Shift+z |
Save | Ctrl+s |
Select All | Ctrl+a |
Undo | Ctrl+z |
Smart Delete (repair connections) | Delete key |
Delete (without repair) | Shift+Delete key |
Readers, Writers, and Transformers
Add Reader | Ctrl+Alt+r |
Add Writer | Ctrl+Alt+w |
Connect Inspector | Select the object(s), then Ctrl+Shift+I |
Connect Logger | Select the object(s), then Ctrl+Shift+L |
Create custom transformer from selected objects, or from bookmark | Ctrl+t |
Duplicate transformer |
Ctrl+d Using Quick Add: If you add a transformer and want to add the same transformer again, press the slash "/" key. The Quick Add box will appear showing the last selected transformer. Press Return to include it, then press Return again to edit its parameters. |
Search
When the cursor focus is on the canvas, press the slash "/" key to enable a quick transformer search. Click the arrow to toggle the search between name and keyword. |
Other Workspace Authoring
Add bookmark | Ctrl+b |
Attach annotation | Select the object(s), then Ctrl+k |
Attach summary annotation | Select the object(s), then Ctrl+Shift+K |
Insert Junction | Ctrl+Shift+J |
Enable/disable objects (including links and feature types) | Ctrl+e |
Running Workspaces
Run translation | F5 |
Prompt and run | Ctrl+r |
Run with full inspection | Shift+F5 |
Run with breakpoints | Ctrl+Shift+F5 |
Toggle breakpoints | F9 |
