You are here: Datums in FMEDatum Definitions
Datum Definition
Certain sites may require a datum that is not predefined in FME. In such a case, a custom datum may be created. Datum definitions may occur in an FME mapping file, as well as in the LocalCoordSysDefs.fme file (<FME_Install_Dir>/Reproject/LocalCoordSysDefs.fme). The syntax of a datum definition is:
DATUM_DEF <datumName> \
DESC_NM <descriptive name> \
SOURCE <source> \
ELLIPSOID <ellipsoid name> \
USE <use type> \
DELTA_X <x value> \
DELTA_Y <y value> \
DELTA_Z <z value> \
BWSCALE <bwscale> \
ROT_X <rotX> \
ROT_Y <rotY> \
ROT_z <rotz>
Example datum definition
This mapping file fragment defines a datum with the BURSA use-type:
DATUM_DEF DHDN \
   DESC_NM “Deutsches Hauptdreicknetz (DHDN)” \
   SOURCE “German Government” \
   ELLIPSOID BESSEL \
   USE BURSA \
   DELTA_X 582.00000000000 \
   DELTA_Y 105.00000000000 \
   DELTA_Z 414.00000000000 \
   BWSCALE 8.3000000000000
   ROT_X -1.0400000000000
   ROT_Y -0.35000000000000
   ROT_Z 3.0800000000000
For additional examples, see <FME_Install_Dir>/Reproject/LocalCoordSysDefs.fme. Note that at least one transformation should be added for most datums. For more information, see Adding a Custom Transformation.
Datum Definition Parameters
Name
Range
Description
Optional
DATUM_DEF
CS-Map identifier name, as described in <FME_Install_Dir>/Reproject/LocalCoordSysDefs.fme
The name of the datum being defined.
No
DESC_NM
any string
A descriptive name for the datum.
Yes
SOURCE any string The individual or agency providing the datum parameters. Yes
ELLIPSOID valid ellipsoid The ellipsoid upon which the datum is based.
No
USE See Datum USE Methods
The type of approximation used when the datum is involved in a datum conversion. Not used in FME 2013 or later workspaces.
Yes
DELTA_X
floating point value
The X component of the vector from the geocenter of the datum being defined to the geocenter of the WGS-84 datum.
Units: meters.
Yes
DELTA_Y floating point value
The Y component of the vector from the geocenter of the datum being defined to the geocentre of the WGS-84 datum. Not used in FME 2013 or later workspaces.
Units: meters.
Yes
DELTA_Z floating point value
The Z component of the vector from the geocenter of the datum being defined to the geocenter of the WGS-84 datum. Not used in FME 2013 or later workspaces.
Units: meters.
Yes
BWSCALE floating point value
The scale factor employed by the BURSA use-type, in parts per million. Not used in FME 2013 or later workspaces.
Yes
ROT_X floating point value
The X rotation factor employed by the BURSA use-type. Not used in FME 2013 or later workspaces.
Units: Seconds of arc.
Yes
ROT_Y floating point value
The Y rotation factor employed by the BURSA use-type. Not used in FME 2013 or later workspaces.
Yes
ROT_Z floating point value
The Z rotation factor employed by the BURSA use-type. Not used in FME 2013 or later workspaces.
Yes
