FME Server Parameters
FME Server parameters reference FME Server system settings when a workspace is run from FME Server. These parameters may be useful when testing or debugging a workspace that is going to be run from FME Server.
FME Server parameters are listed in the table below:
| Parameter | Description |
| FME_DATA_REPOSITORY | Contains the name of the folder used by FME Server’s Web User Interface for temporarily uploading data. |
| FME_SECURITY_ROLES |
Contains the role of the FME Server user who is running the workspace. For example, Administrator and Author are two common roles. |
| FME_SECURITY_USER |
Contains the FME Server user name of the person who is running the workspace. |
| FME_ENGINE |
Contains the name of the FME Server Engine running the workspace. |
| FME_JOB_ID |
FME Server job identifier for the job that invokes this workspace. |
| FME_TOPIC |
Name of the FME Server Notification Service topic used to invoke this workspace. |
| FME_TOPIC_MESSAGE | The location of the FME Server Notification Service message. |
| FME_SERVER_HOST |
The FME Server host name used to invoke this workspace. |
| FME_SERVER_PORT |
The FME Server port used to invoke this workspace. |
| FME_SERVER_WEB_URL |
The FME Server Application Server root URL used to invoke this workspace. |
| FME_SERVER_REQUEST_HEADERS |
The FME Server Web Service request header information, which includes the client IP of requests used to invoke this workspace. |
| FME_SERVER_REQUEST_URI |
The FME Server Web Service URI used to invoke this workspace. |
| FME_SERVER_REQUEST_METHOD | The HTTP request method used to invoke the workspace. |
| FME_SHARED_RESOURCE_TEMP | The name of the FME Server Resource Management folder for storing temporary files created by FME Server. |
| FME_SHARED_RESOURCE_DATA | The name of the FME Server Resource Management folder for storing data files that can be shared between workspaces. |
| FME_SERVER_DEST_DIR | The file path where the FME Server Data Download and Data Streaming services write output data. |
| FME_SERVER_REQUEST_PARAMETERS | The FME Server Web Services request query parameters. Includes query parameters passed as part of the URL, as well as query parameters sent through a POST request body of content type "application/x-www-form-urlencoded" and "multipart/form-data". |
See Also
