Reading from a URL
Another variation on a dataset location is the ability to read data from a URL.
Defining a URL dataset to be read is as simple as entering the URL into the Dataset field within any of FME’s dataset selection tools. After reading, the data will be downloaded and used just as if it were a normal dataset.
To add a reader using a URL instead of a file location:
- Open the Add Reader dialog.
- Select the Format.
- Type or paste the URL of a dataset into the Dataset field
Note: In the Reader parameters dialog for the EsriJSON, GeoJSON, GeoRSS, and JSON formats, a Use Network Authentication parameter is visible only when the dataset is a URL. (For other formats that support URL datasets, this parameter is always present.)
- Click OK to add the reader to the workspace.
Reading from Cloud Storage URLs
FME can also read data from a zip file stored in Google Docs (or from other cloud storage facilities). For example, to read from a Google Doc:
- Share the file publicly and copy its ID number.
- In the Dataset Parameter, use a URL of the form:
https://docs.google.com/uc?export=download&id=XXXX
where XXXX is the ID of the Google document
- URL datasets can be read using either HTTP or FTP. However, password-protected sites are not currently supported.
- FME can read a dataset that is both a URL and a zip file. However, it is not necessary for all URL datasets to be zipped; non-zipped file datasets can also be read.
- FME cannot currently write data directly to a dataset defined by a URL. In this scenario, the data must be written out to the local file system, and then uploaded to the required location using a shutdown script or an HTTPFileUploader transformer.
