Appearance
Select Tools > FME Options and click the Appearance icon.
Fonts
Set the default font to be used on the workspace canvas and in the translation log.
Object Names
This option allows you to specify how object names are truncated: from the left, right, or center.
For example, if object names consist of frequently occurring prefixes, you may want to truncate the text from either the center or the left so you can see more descriptive text at a glance.
This option affects reader, writer, and transformer object names.
Sound Options
Note that by default all the sounds are set to Off. Follow these steps to enable them:
- Click the Configure Sound Events button.
- Scroll through the Program Events until you find FME Workbench or FME View.
- Select the sound to associate with the applicable event.
- Click OK.
Workspace Search Options
By default, the Workspace Search appears as a link in the Navigator. When you click the link, the Workspace Search dialog appears:
You can change the way the Workspace Search appears in Workbench. Check Search bar embedded in Navigator window to change the link in the Navigator to an embedded search bar at the bottom of the Navigator window.
Detailed information on using Workspace Search
Themes
You can change the way objects are displayed on the canvas. Currently, there are two different themes to display: Default and Classic.
Default Theme
Classic Theme
Themes are stored in the <FME_Dir>\res\themes folder. Advanced users can customize the theme in the following ways:
- In the Classic folder, edit any of the images, or edit the settings.ini file.
- Click Install, to upload your own theme, then use the Current Theme drop-down to switch to that theme.
Restore Defaults
Click the Restore Defaults button at the bottom of the dialog to revert this page to FME installation defaults. You will be prompted to confirm your selection.
