Connect to FME Server
This wizard helps you specify connection parameters for FME Server using web requests.
Proxy Server
You can specify a proxy server for the FME Server web connection. Click Tools > FME Options> Network.
FME Server URL: The URL of the FME Server to which you want to connect.
Note: Note that Web Connection is not available for the FME Server Stream Reader, or the FME Server Stream (Attribute) Reader.
Username: The username for the FME Server login account.
Password: The required password for the account.
Use Windows session credentials: You can log in using stored Windows credentials that may contain usernames and passwords that you use to log on to websites or other computers on a network.
Dialog Button Description
Test... Allows you to test the FME Server connection parameters.
Defaults
Allows you to override the default connection parameters with your own, or reset the connection parameters to the default.
Save as My Defaults: Choose this option to save connection parameters for all the fields on the page.
Reset to My Defaults: If previously saved defaults in this field have been edited, you can reset your own defaults.
For more information about connecting to FME Server, contact your System Administrator.
Click the Next button to proceed to the next dialog.
Note: Beginning with FME version 2012, if you try to publish to an older version of FME Server, you will see a warning indicating that certain features may be lost or not be available.
