You are here: FME Readers and Writers > Google KML Reader/Writer > Feature Representation > Overview
Overview
A <Document> element is the root-level container element of a KML dataset that extends the abstract <Feature> element.
The kml_id attribute does not set the filename of the kml file that contains the document; kml_id is only used to set the id attribute of the <Document> element.
