You are here: FME Server Administrator's Guide > Common Configurations > Changing the Web Application Server Hostname and Port
Often you install FME Server and then need to update the application server hostname or port. To make this change, you must modify the FME Server Services definitions:
  1. Log in to the FME Server Web User Interface (http://<host>/fmeserver).
  2. Click Services on the left-hand side.
  3. Click on each service to open the Editing Service page.
  4. In the URL Pattern field, make the appropriate changes and click OK when done.
