Optional. When specified, explicitly sets the authentication realm for Kerberos V5 or MD5 message digest authentication. In terms of Active Directory, the authentication realm is the domain name.
When left unspecified, the authentication realm is assumed to be the domain name of the connected Active Directory domain controller. Windows domains are most commonly configured in this manner.
This configuration parameter expects a capitalized version of the domain name, specified in its fully-qualified domain name (FQDN) form. For example, if the FQDN is domain.net, use DOMAIN.NET.
This parameter is applicable only when SASL authentication is enabled, and either Kerberos V5 or MD5 message digest is used as the SASL authentication mechanism. Specifically, the following configuration parameters must be set:
To obtain the fully-qualified domain name (FQDN):
From a domain computer:
OR:
From the domain controller:
