Depending on the browser used to access the FME Server Web User Interface, additional configuration steps may be required for Integrated Windows Authentication (single sign-on).
Single sign-on is supported in Internet Explorer versions 2 and later.
In most common Windows domain configurations, no additional configuration is necessary. However, if a user is unable to use single sign-on with FME Server, check the following:
Single sign-on is supported in Chrome versions 8 and later.
In most common Windows domain configurations, no additional configuration is necessary. However, if a user is unable to use single sign-on with FME Server, perform the same steps outlined under Internet Explorer.
Single sign-on is supported on all versions of Firefox.
To enable single sign-on in Firefox:
Single sign-on is currently not supported on these browsers.
