To update the FME Server configuration to enable Integrated Windows Authentication (IWA, or "single sign-on") involves the following steps:
Update the user role permissions.
Updating User Role Permissions
Single sign-on users require access to the Token Service to generate security tokens.
Updating fmeServerConfig.txt
This configuration file is located at <FMEServerDir>/Server/fmeServerConfig.txt
SECURITY_DEBUG=true
#SECURITY_LOGIN_TYPE=database
SECURITY_LOGIN_TYPE=activedirectory
SECURITY_AD_USE_SASL_AUTHENTICATION=true
SECURITY_AD_SASL_OPTION_MECHANISM=GSSAPI
SECURITY_AD_PREAUTH_USERNAME=<service account name>
SECURITY_AD_PREAUTH_PASSWORD=<service account password>
SECURITY_AD_USE_SINGLE_SIGN_ON=true
Note: SASL authentication must be enabled and Kerberos V5 must be used as the authentication mechanism. Therefore, depending on your Windows domain configuration, SECURITY_AD_SASL_OPTION_KDC_ADDRESS and SECURITY_AD_SASL_OPTION_REALM may be required. For more information, see SECURITY_AD_SASL_OPTION_MECHANISM.
Updating propertiesFile.properties
When FME Server is installed using express installation, this configuration file is located at <FMEServerDir>/Utilities/tomcat/webapps/fmeserver/WEB-INF/conf/propertiesFile.properties.
Verify that the parameter SINGLE_SIGN_ON_AUTH_URL is set to the correct protocol. By default, http is used as the protocol. If SSL is enabled for the web application server, then update the protocol to https.
