You are here: FME Server Administrator's Guide > Performing an Installation for High Availability > Installing for Core Failover > Install the FME Engines
Install the FME Engines by starting the FME Server installer on another computer (<engineHost>), and selecting the "Engine" setup type. For more information, see Install the FME Engines.
Note:  In a high availability environment, we recommend assigning unique names to FME Engines. However, if multiple FME Engine hosts have the same FME Engine name, the job routing server configuration applies to all FME Engines with the same name in the same way regardless of which host it resides on. For more information about job routing, see Managing Job Distribution Between FME Engines.
Optionally, proceed to Configure a Notification When Failover Occurs.
