You are here: FME Server Administrator's Guide > Securing FME Server > Connecting to Active Directory
FME Server's security framework can be configured to use Active Directory for user authentication and user grouping. In this manner, a server administrator can utilize an existing user account database and associated security permissions.
In Active Directory, user accounts are given security permissions by placing them in one or more security groups. The integration works by effectively mapping Active Directory security groups to FME Server roles. In the Web User Interface, a role is then given a set of resources it can access and permissions on those resources. Therefore, if a security group has access to a particular resource, so do its member users.
Note:  FME Server includes the fmesuperuser role, which allows full access to all server resources. It is not possible to map an Active Directory security group to this role in the same manner as other roles. For more information, see Enabling fmesuperuser Privileges in Active Directory.
Getting Started
To configure FME Server to use Active Directory, three steps are required:
  1. Identify security groups or user accounts to allow access.
  2. Add each security group or user account as a user role.
  3. Enable Active Directory integration in the FME Server configuration file.
These steps are described in detail in the following sections.
This document assumes that you have not modified FME Server security components and that you are using the default security settings that ship with FME Server (that is, the built-in database security module).
Identify Security Groups or User Accounts
Identify the security groups or user accounts to which you want to allow access to FME Server, and compile a list of their distinguished names (DNs).
You can acquire DNs from the domain administrator or through an Active Directory browser, such as ADExplorer (http://technet.microsoft.com/en-us/sysinternals/bb963907). The DN of a security group takes on the general form:
CN=groupname,OU=organizationunit,...,DC=mydomain,DC=com
The DN of a user account takes on the general form:
CN=username,OU=organizationunit,...,DC=mydomain,DC=com
Add Security Groups or User Accounts as Roles
Through the FME Server web user interface, add each security group's or user account's DN as a user role. For each user role, specify the FME Server resources that the role can access.
  1. Using a web browser, access the FME Server Web Interface—for example, http://localhost/fmeserver.
  2. If you are not already authenticated, enter your credentials, and click Login.
  3. Click Security on the left-hand side to access the security page.
  4. Click the Roles tab.
  5. Click New, and then specify the security group's or user account's DN.
  6. Click OK to add the new user role.
    The user membership is maintained in Active Directory.
  7. Click Permissions, and select the newly added role.
  8. Specify the FME Server resources that you want to make accessible to this security group, and then click Apply.
  9. Repeat steps 4 through 8 for each security group or user account you want to add.
Edit the FME Server configuration file (<FMEServerDir>\Server\fmeServerConfig.txt) to use Active Directory. Then restart the server.
Note:  For more information about configuring the FME Server configuration file for Active Directory integration, see Configuring FME Server with Active Directory.
  1. Open the FME Server configuration file, fmeServerConfig.txt, located in the subdirectory Server of your FME Server install directory.
  2. Under the Security heading, comment out (#) the following line:
    SECURITY_LOGIN_TYPE=database
  3. Uncomment (#) the following lines:
    SECURITY_LOGIN_TYPE=activedirectory
    SECURITY_AD_SERVER_AUTODETECT=true
    SECURITY_AD_USE_SASL_AUTHENTICATION=true
    SECURITY_AD_SASL_OPTION_MECHANISM=GSSAPI
    SECURITY_AD_PREAUTH_USERNAME=
    SECURITY_AD_PREAUTH_PASSWORD=
    FME Server will attempt to automatically detect Active Directory. If this fails, provide the host and port for your Active Directory using the following lines:
    SECURITY_AD_SERVER_AUTODETECT=false
    SECURITY_AD_SERVER_COUNT=1
    SECURITY_AD_SERVER_HOST1=<host>
    SECURITY_AD_SERVER_PORT1=<port>(typically 389, or 636 when using SSL)
    Provide your service account credentials in SECURITY_AD_PREAUTH_USERNAME and SECURITY_AD_PREAUTH_PASSWORD. A service account is required for certain features of FME Server (including token authentication and single sign-on authentication).
  4. If you are connecting to Active Directory over a Secure Sockets Layer (SSL), add the following line:
    SECURITY_AD_USE_SSL=true
  5. (Optional) Specify a service acount name and password by adding the following lines:
  6. SECURITY_AD_PREAUTH_USERNAME=<account_name>
    SECURITY_AD_PREAUTH_PASSWORD=<acount_password>
    This step is necessary for reliable Token Service access to the REST API. For more information, see Configuring FME Server with Active Directory.
  7. Save the configuration file.
  8. Restart FME Server.
    For more information, see Starting and Stopping FME Server.
  9. Log in using your Active Directory credentials.
Security Management Using Active Directory
When using Active Directory for user authentication and authorization, the Security Management interface has some modifications.
User Accounts View
The User Accounts view is a live list of Active Directory users that can access components of FME Server. A server administrator cannot modify this list, since it is fetched from Active Directory. The list includes all users implicated by the enabled Active Directory security groups specified in user roles.
Note:  FME Server populates this view by using Lightweight Directory Access Protocol's (LDAP) virtual list view (VLV) control. Your Active Directory server must have this feature enabled in order to display a live User Accounts view.
User Roles View
The User Roles view is a live list of Active Directory security groups who can access components of FME Server. A server administrator can modify this list, which is stored in the local security database, to add Active Directory security groups or remove existing groups.
Note:  User roles can accept Active Directory security groups or user accounts. It is possible through the user interface to add user roles that are not security groups; however, they are ignored. Examples of invalid user roles when using Active Directory include:
Troubleshooting
Active Directory-based security might be easier to set up in some server environments, due to the high degree of variability of the security hierarchy. If you are having difficulty configuring FME Server's security framework to use Active Directory, check the following troubleshooting tips for options.
Enable Debug Logging
Enabling debug logging for FME Server's security framework allows more verbose logging during many Active Directory operations. Examining log messages might provide insight into the failing operation.
  2. Under the Security heading, locate the parameter SECURITY_DEBUG and set it to true.
  3. Restart FME Server.
  4. Examine the log files for additional information pertaining to Active Directory operations.
Use the Active Directory Configuration Tool
Bundled with your FME Server installation is an Active Directory configuration utility, located at:
<FMEServerDir>/Utilities/ActiveDirectoryConfigurationConsole.bat
This utility allows you to test various Active Directory configuration parameters and uses the same API to contact your domain controller and FME Server.
The utility presents the following menu options:
