System parameters reference a specific system setting. Obtaining a value from a system parameter is often easier than having to define a value at run-time.
System parameters have various uses, including:
($FME_MF_DIR)myFileName.txt.
FME_BUILD_NUM could be checked to ensure the FME engine running the workspace is sufficiently new; this could be of particular interest on FME Server where multiple engines might each be a different build number. Another example is FME_SECURITY_ROLES, which might help to filter features in a workspace dependent on the access rights given to a particular user.System parameters are listed in the table below:
| Parameter | Description |
| FME_BUILD_NUM | Contains the build number of the FME engine that is executing the workspace. |
| FME_DATA_REPOSITORY | Contains the name of the directory used by FME Server’s Web User Interface for temporarily uploading data. |
| FME_HOME | Expands to the directory where the FME executable resides. It includes a trailing slash, independent of the platform. |
| FME_MF_DIR | Contains the name of the directory in which the current workspace resides and, in some cases, the location of the source datasets. |
| FME_SECURITY_ROLES |
Contains the role of the user who is running the workspace. For example, Administrator and Author are two common roles. This parameter applies only to workspaces run on FME Server. |
| FME_SECURITY_USER |
Contains the username of the person who is running the workspace. This parameter applies only to workspaces run on FME Server. |
| FME_SERVER_NAME |
Contains the hostname of the FME Server running the workspace. This parameter applies only to workspaces run on FME Server. |
