Select Tools > Options and click the Runtime icon.
Sets the CPU priority for running translations. In most cases, the default Normal setting will be adequate. If you regularly run large translations, you can keep the default setting, or change it to Low, so the translations won't dominate your CPU (and so you can do other work in the foreground while the translation is running). If you have other CPU-intensive tasks running concurrently, you may want to set the priority to High to make sure the translation gets its share of the CPU.
If you check this box, FME will transmit information about your version of Windows and how you use FME. The information collection process is completely anonymous, and your results will be automatically combined with other users' results. The resulting statistics will help us identify trends and usage patterns (for example, which formats and processing facilities are utilized more than others), which in turn will help us focus our development efforts for future versions of FME. We will not collect your name, address or any other personally identifiable information.
Choose the type of messages that you want to view in the log file. For example, you might want the log to display only Warnings and Errors.
To choose a different Python interpreter for FME, locate the interpreter's DLL file and follow these steps:
python26.dll).For more information on Python and FME, see Startup and Shutdown Python Scripts.
