Select Tools > Options and click the Default Paths icon.
Sets the default location to save your workspaces. You can choose to always save to the source data location, a custom location, or a My FME Workspaces subfolder in My Documents.
When you create a workspace, FME suggests a default workspace name based
on the formats used in the workspace. For example, if your workspace is
set up to read from an Esri Shapefile and write to both an Access MDB
file and AutoCAD drawing, then shape2mdb_dwg.fmw
would be the suggested default name.
A shared resource is any FME file that has been made available for other users to use. These files are:
This option is especially useful for workgroups. For instance, if an entire workgroup uses just a few custom coordinate system definitions, keeping these definitions in one place means that everyone doesn't have to have a copy. Then, whenever any of the definitions are updated, the entire group automatically has access to the new version.
button.The directory name will appear in the list.
Every time you start FME, it will scan the folders for new or updated files.
Note: Any locally stored formats, transformers and coordinate systems take precedence over any shared directories. If there is a naming conflict, for example, if you have a transformer with the same name as a transformer in a shared directory, FME will always use the transformer that is stored locally.
See FME Server Shared Directories.
Select the directory name and click the Delete button.
