When you install FME, grid shift files for the following datum transformations are automatically installed:
Please note that different jurisdictions and standards may require the use of specific grid shift files not necessarily provided by Safe Software. Safe is unable to provide grid shift files for the transformations listed below. In these cases, it is necessary to contact the appropriate jurisdiction to obtain the required files.
To obtain grid shift files for Canadian CSRS and ATS77 transformations, Provincial contacts are available here:
You cannot perform implicit NAD83 <-> NAD27 datum shifts until Canadian or U.S. grid files have been chosen.
In FME, you can specify the grid files to use. From the Workbench menu bar, click Tools > FME Options and then click the Coordinate Systems icon.
It is not necessary to choose grid files using this method if a NAD83 <-> NAD27 transformation is explicitly chosen in a CsmapReprojector transformer.
For more information on individual grid shift files, see USE Data Transformation Approximations.
