FME Workbench Keyboard Shortcuts
Tip  Click to open a PDF of this page.
Jump to Windows/Linux shortcuts
Jump to Mac shortcuts
Windows/Linux
General Viewing
Action Shortcut (Windows/Linux)
New (create a new workspace)
Ctrl n
Generate workspace
Ctrl g
Open
Ctrl o
Exit (FME Workbench)
Ctrl q
Close (workspace)
Ctrl w
Change to next tab
Ctrl Tab
Change to previous tab
Ctrl Shift Tab
Tab number
Ctrl [tab number]
Close current tab
Ctrl F4
Open containing folder
Ctrl o
Maximize canvas to current window size
Shift F11
Maximize canvas to full screen
F11
Zoom-in
Ctrl +
Zoom-out
Ctrl -
Zoom 100%
Ctrl 0
Zoom in and out
Ctrl + scroll wheel
Pan
Click scroll wheel (or middle mouse button) and drag cursor.
Return cursor to action arrow.
Right-click anywhere on the canvas.
Search:
  • Workspace if the focus is in the workspace or the Navigator
  • Log if the focus is in the Log window
Ctrl f
F3
Connection Style
Ctrl Shift C
Print
Ctrl p
Help
Select an object, then F1
Viewing Data in Visual Preview
Task Shortcut (Windows/Linux)
Toggle automatic inspect on selection Ctrl Alt A
Toggle Display Control Ctrl Alt `
Toggle table view Ctrl Alt 1
Toggle graphics view
Ctrl Alt 2,
Ctrl Alt 3,
Ctrl Alt 4
Show/hide Feature Information window Ctrl Alt F
Open in FME Data Inspector Ctrl Alt D
General Editing
Cut Ctrl x
Copy Ctrl c
Paste
Paste With Formatting (annotations only)
Ctrl v
Paste Without Formatting (annotations only) CtrlShiftV
Redo Ctrl y
Save Ctrl s
Select All Ctrl a
Undo Ctrl z
Smart Delete (repair connections) Delete
Delete (without repair) Shift +Delete
Restrict click and drag of objects to vertical or horizontal (depending on direction of initial movement)
Select the object(s), hold Shift and drag.
Temporarily disable Snap to Grid while dragging objects.
Hold Ctrl and drag.
Readers, Writers, and Transformers
Add Reader Ctrl Alt r
Add Writer Ctrl Alt w
Show Parameters Select an object, then Enter.
Connect Inspector Select the object(s), then Ctrl Shift I
Connect Logger Select the object(s), then Ctrl Shift L
Create custom transformer Select one or more transformers, then Ctrl t
Duplicate transformer
Ctrl d
Using Quick Add: If you add a transformer and want to add the same transformer again, press /. The Quick Add box will appear showing the last selected transformer. Press Return to include it, then press Return again to edit its parameters.
Rename Select the object, then F2
Reload transformers Ctrl Shift R
Search transformers, readers, and writers /
Other Workspace Authoring
Add bookmark
Ctrl b
Attach annotation
Select the object(s), then Ctrl k
Show summary annotation
Select the object(s), then Ctrl Shift K
Insert Junction
Ctrl Shift J
Enable/disable objects (including links and feature types)
Ctrl e
Compare workspaces and merge differences
Ctrl Alt c
Running Workspaces
Run translation F5
Rerun entire workspace Shift F5
Enable Prompt for User Parameters Ctrl Alt F5
Prompt and run Ctrl r
Enable feature caching Ctrl F5
Enable feature caching + "Run From This" F6
Enable feature caching + "Run To This" Shift F6
Run with breakpoints Ctrl Shift F5
Toggle breakpoints Select connection, then F9
Mac
Action Shortcut (Mac)
n
Generate workspace
Shift n
Open
o
q
Close (workspace)
w
Change to next tab
Tab number
[tab number]
Close current tab
w
o
Shift F11
F11
Zoom-in
Zoom-out
Zoom 100%
0
Zoom in and out
+ scroll wheel
Pan
Search:
f
Connection Style
Shift C
Print
p
Help
Task Shortcut (Mac)
Toggle automatic inspect on selection Option A
Toggle Display Control Option `
Toggle table view Option 1
Option 2,
Option 3,
Option 4
Show/hide Feature Information window Option F
Open in FME Data Inspector Shift D
General Editing
Task Shortcut (Mac)
Cut x
Copy c
Paste v
Ctrlv
Redo shift+ z
Save s
Select All a
Undo z
Delete (without repair) Shift Delete
Select the object(s), hold down Shift, then drag.
Task Shortcut (Mac)
Add Reader Option r
Add Writer Option w
Create custom transformer Select one or more transformers, then t
Duplicate transformer d
Reload transformers Shift R
Task Shortcut (Mac)
Add bookmark
b
Attach annotation
Select the object(s), then k
Select the object(s), then Shift K
Insert Junction
Shift J
e
Option c
Running Workspaces
Task Shortcut (Mac)
Run translation F5
Alt F5
Note  MacOS Show Accessibility Controls shortcut must be disabled in System Preferences.
Prompt and run r
Enable feature caching F5
Run with breakpoints Shift F5
