Oracle Spatial Object Writer Parameters
About Database Connections
Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Using Database Connections.
Note that Database Connection parameters differ slightly, depending on context and/or database format.
Connection
From the Connection parameter in a database format, you can do one of the following:
  • Select an existing, previously defined connection. See the section Reusing a Database Connection in Using Database Connections
  • Select Add Database Connection to define a new connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Persistent Connection
If this parameter is checked (default), the Oracle database connection remains open for other requestors. A persistent connection is useful for workspaces that are long-running, or published using FME Flow.
If this parameter is unchecked, the connection to the Oracle database is closed as soon as possible after data processing is complete.
Layer Parameters
Uppercase Column Names
If this parameter is checked, the writer automatically makes the column names uppercase, and disallows characters in the column names that require quoting within Oracle.
This parameter is only applicable when generating a writer.
Minimum and Maximum X and Y
These values apply to the entire layer – features with coordinate values outside this range will not be correctly indexed.
Spatial Column
Traditionally, FME would assign a GEOM name to all geometry columns stored in Oracle databases in all generated workspace. This gives you the option of modifying what the geometry column will be named in tables created by FME.
Create Spatial Index
Indicates whether or not spatial indexes are to be created as part of the data load.
If No is selected, no spatial index creation will be done.
