Oracle Non-Spatial Reader/Writer
FME can read and write attribute data stored using Oracle. This module communicates directly with Oracle for maximum throughput.
Using FME with Oracle Formats
Oracle Format Data Type
attributes only
Oracle Spatial GeoRaster Reader/Writer
raster
Oracle Spatial Object Reader/Writer
object relational model (referred to as the object model)
Oracle Spatial Point Cloud Reader/Writer
point cloud
Oracle Spatial Relational Reader/Writer
relational model
Oracle Non-Spatial Product and System Requirements
Compatibility  Oracle libraries are not yet available for the macOS M1 ARM architecture (Apple Silicon). Please use an alternative platform such as Intel macOS.
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
Yes
Yes
- Linux Intel: Yes
- Linux ARM: Yes
- macOS Intel: Yes
- macOS ARM: No
Writer
Yes
Yes
Yes
Yes
- Linux Intel: Yes
- Linux ARM: Yes
- macOS Intel: Yes
- macOS ARM: No
Format Notes
Oracle and FME
Description
Oracle Instant Client
Instant Client can be used to run your OCI, OCCI, JDBC, and ODBC applications without installing a full Oracle Client. Instant Client supports SQL*Plus.
See the FME Community for more information on how Instant Client works with FME.
Oracle Wallet To use an Oracle Wallet with FME, leave the Username and Password parameters empty, and enter the name of the Oracle Wallet as the value of the Service Name or Easy Connect parameter.
Reader Overview
This reader reads non-spatial tables from Oracle Non-spatial databases.
Writer Overview
The Oracle Non-Spatial writer module stores attribute data in an Oracle database. The writer supports the following features:
Feature
Description
Transaction Support
Provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
Table Creation
Uses the information within the FME workspace to automatically create database tables as needed.
Table Dropping
Allows each table to be written to be dropped if recreating, or truncated if appending.
Index Creation
Sets up and populates all needed indexes and index tables as part of the loading process.
Bulk Loading
Uses a bulk loading technique to ensure speedy data load.
