Oracle Autonomous Spatial Object Reader/Writer
Autonomous Database includes Oracle Spatial. Oracle Autonomous Database technology was designed to deliver automated patching, upgrades, and maintenance.
FME can read and write geometric and attribute data stored using Oracle Autonomous Spatial.
Using FME with Oracle Autonomous Formats
Oracle Format Data Type Characteristics
  • Communicates directly with Oracle Spatial for maximum throughput.
  • This object-relational model is often referred to as simply the object model, to prevent confusion with the pure relational model.
Oracle Autonomous Non-Spatial
read and write attributes only
  • Communicates directly with Oracle for maximum throughput.
  • Relational model reads and writes attribute data stored using Oracle.
Connecting to Oracle Autonomous Databases
Oracle Resources
FME Community Resources
Format Notes
3D Geometry Support
Reading and writing of 3D surfaces and solids is available only for Oracle 11g and above.
Oracle Instant Client
Instant Client can be used to run your OCI, OCCI, JDBC, and ODBC applications without installing a full Oracle Client. Instant Client supports SQL*Plus.
For more information on how it works with FME, see
See the FME Community for more information on how Instant Client works with FME.
Oracle Wallet
To use an Oracle Wallet with FME, leave the Username and Password parameters empty, and enter the name of the Oracle Wallet as the value of the Service Name or Easy Connect parameter.
Oracle Autonomous Spatial Product and System Requirements
Compatibility  Oracle libraries are not yet available for the macOS M1 ARM architecture (Apple Silicon). Please use an alternative platform such as Intel macOS.
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
Yes
Yes
- Linux Intel: Yes
- Linux ARM: Yes
- macOS Intel: Yes
- macOS ARM: No
Writer
Yes
Yes
Yes
Yes
- Linux Intel: Yes
- Linux ARM: Yes
- macOS Intel: Yes
- macOS ARM: No
Dependencies  This format requires FME 2020.1 and above.
Reader Overview
The Oracle Autonomous Spatial Object reader reads attributes and geometry from Spatial tables in an Oracle Autonomous Data Warehouse.
Writer Overview
The Oracle Autonomous Spatial Object writer stores geometric and attribute data in an Oracle Autonomous Data Warehouse. Both uppercase and lowercase table names are supported.
The writer provides the following capabilities:
  • Transaction Support: Provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
  • Table Creation: Uses the information within the FME workspace to automatically create database tables as needed.
  • Table Dropping: Optionally, allows each table to be written to be dropped if recreating, or truncated if appending.
  • Index Creation: Sets up and populates all needed indexes and index tables as part of the loading process.
  • Bulk Loading: Uses a bulk loading technique to ensure speedy data load.
