IBM Informix Non-Spatial (JDBC) Reader/Writer
FME can read and write attribute data held in IBM Informix database tables.
For information about the IBM Informix JDBC driver, please see Product and System Requirements below.
Installing the JDBC Driver
To view instructions for installing the JDBC driver, please see Getting Started with JDBC.
IBM Informix Non-Spatial Product and System Requirements
Note  FME provides read and write access via IBM's Informix JDBC driver, which is not bundled with FME. For information about downloading the driver, see Download Informix Products on the IBM Support web page. Please note that the IBM Informix Non-Spatial (JDBC) format requires Informix JDBC driver version 4.10.JC4DE or newer.
https://www-01.ibm.com/marketing/iwm/tnd/search.jsp?go=y&rs=ifxjdbc
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
No
Yes
No
No
Writer
Yes
Yes
No
Yes
No
No
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
FME_JVM_MIN_HEAP_SIZE
Initial heap size for initializing the JVM. If unset, the default value is 1024K.
This variable must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
6291456
6144k
6m
FME_JVM_MAX_HEAP_SIZE
Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
This variable must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
83886080
81920k
80m
Tip  To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
Memory Usage (applicable to writers only): Changing the value in the writer parameter Features Per Transaction can control the number of features that FME places in each transaction before a transaction is committed to the database.
