FME Form: 2026.1 BETA
Downloading From FME Flow Data Virtualization
Choose File > Download from FME Flow Data Virtualization, or click the Data Virtualization icon on the Start page or Toolbar. The Download from FME Flow Data Virtualization dialog opens. Complete the fields below, and click Download.
  • FME Flow Connection: Specify a connection to an FME Flow deployment. For more information, see Connecting to FME Flow.
  • Select an API: Select the Data Virtualization API that references the workspace you want to download.
  • Select the root download directory: Specify a directory in which to save the workspace and associated files.
  • Select an Endpoint: Select the workspace you want to download. You can expand each workspace to see the endpoint to which it is assigned. Use the search field below to limit the list to workspaces or endpoints that contain the specified string.
What's Next?
After you click Download, the workspace for the specified endpoint opens and is ready to be configured with your transformation requirements. The workspace is equipped with a Data Virtualization Reader and Writer.
For testing purposes, Data Virtualization workspaces provide an interface for test running the incoming request for data from the specified endpoint with a customizable JSON template that is fully customizable, or populated from a preexisting sample data request. For more information, see Test Running Data Virtualization Workspaces.
See Also
