FME Form: 2026.1 BETA
Data Caching
Data caching seamlessly integrates the workspace with Data Preview or the FME Data Inspector. When enabled, output ports record feature data in temporary caches, which you can view and inspect after completing a full or partial translation, or even mid-translation.
Data caching is enabled by default. If it is disabled, do any of the following to re-enable:
- From the Menu Bar, select Run > Data Caching > Enable Data Caching.
- Click the Caching icon on the Toolbar.
- Enter Ctrl+F5.
- Set the Enable Data Caching workspace parameter.
This example workspace shows the canvas with generated caches after a workspace is run with data caching enabled:
To view cached features, click a cache icon on an output port. Complete caches are available to view after a translation runs successfully. Caches can also be viewed while a translation is still running. While running, all caches are regenerated each time an additional cache is selected for viewing.
The coloring of icons varies depending on the state of the cache, as follows:
Cache Icon |
Cache Icon When Clicked for Viewing |
Meaning |
Meaning When the Icon is Animated |
The translation completed successfully and a complete cache is available to view. |
The translation is running and a cache is available to view before completion. |
The translation stopped and a cache that is considered stale is available to view. For more information, see Stale and Incomplete Caches (below). |
The translation is running and a cache that is considered stale is available to view before the translation completes. For more information, see Stale and Incomplete Caches (below). |
The translation stopped or failed and an incomplete cache that is considered up-to-date is available to view. For more information, see Stale and Incomplete Caches (below). |
The feature data output at the selected port is presented in the Data Preview pane or the FME Data Inspector, depending on your Data Inspection setting in Utilities > FME Options > Workbench.
Tip During translation, messages may display with useful information to guide you in viewing more updated caches or options on stopping or pausing translation.
Limitations of Data Caching
When data caching is enabled, keep in mind the following:
- Data caching affects system resources, and because all features are recorded and stored, it can also affect disk space. You may not want to keep all workspaces in this mode. Alternatively, consider Running and Inspecting Part of a Workspace (below) or Skip Caching in Collapsed Bookmarks (below).
- Data caches do not maintain input feature order, such as when workspaces run from multiple caches, or transformers run in Group Processing mode that specifies Complete Groups: When Group Changes (Advanced). To avoid unexpected results, place a junction before the location in the workspace where you expect a specific order, and use the junction as the basis for starting or stopping a partial translation (see Running and Inspecting Part of a Workspace, below).
- To generate separate translation log files for each process of a translation that runs multiple processes, data caching must be off.
You can select one or more objects on the canvas, and run only part of a workspace for inspection. Large workspaces, especially those that access large data sets, can take time to run in full. Running a partial workspace can save time and resources when:
- You make a change to a workspace, and you want to see quickly how the change affects your data.
- You are preparing data for input, and you want to see quickly how it looks.
You can run partial workspaces in the following ways:
Run From This (or Selected) (F6): All parts of the workspace that flow from a selected object (or objects) run. Required upstream nodes without up-to-date caches are also run.
Run Just This (or Selected) (Ctrl+Alt+F6): Only a selected object (or objects) runs. If a collapsed bookmark is included in the selection, only the objects within the bookmark run. Required upstream nodes without up-to-date caches are also run.
Run To This (or Selected) (Shift+F6): All parts of the workspace that flow to a selected object (or objects) run.
Run Between Selected (Ctrl+Shift+F6): All parts of the workspace that flow between the selected objects run. Required upstream nodes without up-to-date caches are also run.
These options are available in the mini-toolbar above any selected canvas object, under Run > Run Selected on the Menu Bar, under Run on the Toolbar, or as keyboard shortcuts (noted above).
Working with Data Caches - Other Considerations
A data cache is considered stale if you make a change to the workspace, after or during translation, that invalidates one or more caches. If a workspace fails or is manually stopped mid-translation, the incomplete cache that results may be considered stale depending on the cache settings of the workspace (below).
If a workspace is re-run, stale caches always regenerate if required for downstream translation.
A data cache is considered incomplete if the corresponding workspace fails or is manually stopped mid-translation.
The following parameters, located under Run on the Menu Bar, instruct FME on how to treat incomplete caches when you re-run the workspace.
- Regenerate Incomplete Caches (Mark as Stale) (default): When the workspace re-runs, incomplete caches are regenerated if required for downstream translation.
- Use Incomplete Caches (Mark as Up-to-date): When the workspace re-runs, incomplete caches are considered up-to-date and not regenerated.
Alternatively, set the Incomplete Cache Handling workspace parameter.
Cache Icons and Their Meanings
The coloring of cache icons indicates whether they are considered complete, stale, or incomplete and up-to-date.
Cache Icon |
Meaning |
The translation stopped and a cache that is considered stale is available to view. |
The translation is running and a cache that is considered stale is available to view before the translation completes. |
The translation stopped or failed and an incomplete cache that is considered up-to-date is available to view. |
To conserve resources, you can prevent FME from caching portions of a workspace, if you know those portions do not require caching for producing accurate runs. Place the parts of the workspace you do not want to be cached in a bookmark, then collapse the bookmark. Any ports inside the collapsed bookmark that do not output features to components outside of the bookmark will not produce caches.
Clearing Caches
When a workspace containing data caches reruns, FME clears the cache at the point where the run originates, and all downstream caches. This clearing occurs at the start of the run.
To assist in troubleshooting, you can clear individual data caches manually before rerunning a workspace in data caching mode. When you clear the cache of a selected reader or transformer, the cache of that item, and all caches downstream of that item, are cleared. When you clear the caches of items in a selected bookmark, the caches of all items within the bookmark, and all caches downstream of those items, are cleared. To clear caches, right-click on a reader, transformer, or bookmark, and select Clear Data Cache.
Viewing and Controlling Caching Mid-Translation
You cannot enable data caching during a translation, or re-enable caching after disabling it mid-translation. If you disable caching mid-translation, caches are removed.
