FME Transformers: 2025.2 BETA
YAMLtoJSONConverter
Converts YAML to JSON.
Converting YAML for use with JSON transformers in FME.
Features successfully processed, with JSON results written to an attribute or file as specified in parameters.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute will be added along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Input Source |
Allows for selecting between one of two options for YAML Input: Attribute or File. |
YAML Document |
Enabled when Input Source is Attribute. The YAML Document can come from a string expression, including attribute values. |
File |
Enabled when Input Source is File. The source YAML can be read from a local file at a specified file path. |
Output |
Allow for selecting between one of two options for JSON Output: Attribute or File. |
Output Attribute |
Enabled when Output is Attribute. Used to set the name of the Output Attribute carrying the resulting JSON. |
File Destination |
Enabled when Output is File. The resulting JSON will be output to the specified file path. |
Pretty Print |
Pretty Print: The JSON text will be formatted by adding indentations and new lines for improved readability. Linear: All JSON contents will be put on a single line, to reduce the size of the JSON text. |
Indent Size |
Select a value from 0 to 9. |
Dependencies | None |
Aliases | |
History |
Search for all results about the YAMLtoJSONConverter on the FME Community.
