FME Transformers: 2025.2 BETA
VertexCreator
Creates a single vertex to replace, be appended to, or be inserted into existing geometry.
- Creating point geometry from non-spatial data with coordinates as attributes
- Adding known coordinates to existing geometry
The VertexCreator receives features with any geometry and creates a single vertex at specified coordinates, performing one of these actions:
- Add a new point to the existing geometry
- Replace the existing geometry completely with a single point
- Add a new point to the geometry at a specific position (index)
- Replace an existing vertex at a specific position (index)
The actions available vary according to the input feature’s geometry type:
Mode |
Geometry |
Add Point |
Replace with Point |
Insert Point at Index |
Replace Point at Index |
Null |
Yes |
Yes |
Yes |
Yes |
Point |
Yes |
Yes |
Yes |
Yes |
Line |
Yes |
Yes |
Yes |
Yes |
Arc |
Yes |
Yes |
Path |
Yes |
Yes |
Yes/No* |
Yes/No* |
Area |
Yes |
Yes |
Yes |
3D Object |
Yes |
Raster |
Yes |
Point Cloud |
Yes |
Multi/Aggregate |
Yes |
If the selected Mode is not supported for the input feature’s geometry type, the feature will be output via the <Rejected> port.
* Using indices on paths containing arcs is not recommended.
If the X, Y, or Z Value parameters are set to an attribute value, those attributes may be optionally removed from the output features.
Modes
Mode |
Action |
Add Point |
Appends the new vertex to the end of the existing feature.
Input geometry of any type is discarded and a single point is output. A coordinate system may be specified. |
A new vertex is inserted at the specified index position. When entering vertex indices, note that:
The existing vertex at the specified index position is set to the new coordinates. |
Measures and Z Values
Z values are supported. If there is a conflict - either the input feature or the new vertex has a z value and the other does not, the result is determined by the Measures/Z Conflict Value parameter:
- Compute: Missing z values on either the input feature or the new point are calculated according to neighboring vertices. At the beginning or end of the feature the neighboring value is used. If only one value is available, it is applied to all vertices.
- None (Drop Values): All z values are discarded and 2D geometry is output.
- Custom Value: The provided value is applied to all vertices without a z value.
Exception: When Mode is Add Point, if a 2D point is added to a 3D feature and its coordinates match either endpoint of the input feature, the z value will be taken from that endpoint.
Measures are treated similarly, where new vertices inserted receive interpolated values when Treat Measures as is Continuous. Note that existing measures are not recalculated. When a vertex is added at the end the neighboring value is used.
When Treat Measures as is Discrete, a vertex inserted or replaced at an index position receives the measure value of the existing vertex at that index.
In this example, we have a CSV file containing locations of drinking fountains. We want to create point geometry from the coordinates.
The features are routed into a VertexCreator.
In the parameters dialog, Mode is set to Replace with Point and the X and Y Values are set to the corresponding attributes. The appropriate coordinate system is specified.
Note that Mode > Add Point would also create point geometry in this case, but does not have the option of setting a coordinate system.
Remove Attributes is set to Yes, as they will no longer be needed once the geometry is created.
The output features have point geometry, and the specified coordinate attributes have been removed.
- This transformer requires explicit coordinates. To generate vertices based on geometry or spatial relationships see the Snipper, Densifier, Intersector, Clipper and various overlayer transformers.
- Aggregates are not supported. A Deaggregator may be used prior to this transformer.
- This transformer can close lines into areas, but the LineCloser may be more appropriate in some cases.
Features with any type of geometry.
Features with new vertices as specified in parameters.
Features that receive non-numeric values (including null) for any numeric parameters are output via this port.
Incompatible combinations of Mode and input geometry type will also be rejected.
INVALID_PARAMETER_X
INVALID_PARAMETER_Y
INVALID_PARAMETER_Z
INVALID_PARAMETER_INDEX
Mode |
Select the action to take with the new vertex:
See Modes above. |
X Value |
Specify the X coordinate for the vertex. |
Y Value |
Specify the Y coordinate for the vertex. |
Z Value |
(Optional) Specify the Z coordinate for the vertex. If specified, the resulting feature will have 3D geometry. |
Remove Attributes |
If any of X, Y, and Z Value are set to an attribute value, select a method for handling those attributes:
Coordinate System |
When Mode is Replace with Point, optionally specify a coordinate system for the new point geometry. |
Index |
When Mode is Insert Point at Index or Replace Point at Index, specify the index number to insert at or replace. See Modes above. |
Measures/Z Conflict Value |
Select a method for handling geometries that have a measure, but are missing at least one value, or that have z values but are missing at least one value.
See Measures and Z Values above. |
Treat Measures as |
When Measures/Z Conflict Value is Compute, select a method of calculating new measures:
Ignore Duplicated Coordinates |
When Mode is Add Point and the new vertex is the same as the last coordinate of the input feature, select a method of handling the duplicated vertices:
Closed Line Handling |
Select a method of handling lines where the first and last vertices (whether new or existing) are the same:
Dependencies | None |
Aliases | 2DPointAdder 3DPointAdder 2DPointReplacer 3DPointReplacer CoordinateCreator CoordinateReplacer |
History |
Search for all results about the VertexCreator on the FME Community.
