FME Transformers: 2025.2 BETA
Categories
Calculated Values
Coordinates
TextureCoordinateSetter
Assigns texture coordinates to surfaces.
  • This transformer works only with surfaces, not including triangle strips and triangle fans.
  • Multi-surfaces are not yet supported.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the TextureCoordinateSetter on the FME Community.
