FME Transformers: 2025.2 BETA
Categories
Calculated Values
Strings
StringLengthCalculator
Calculates the length of strings and the number of bytes in a blob.
Example
To calculate the number of bytes in a blob:
  1. Add a raster format reader (for example, TIFF).
  2. Connect a RasterExtractor followed by a StringLengthCalculator.
  3. In the StringLengthCalculator parameters, select _rasterBlob as the Source Attribute.
  4. Connect an Inspector transformer.
  5. Run the workspace.
Locate the _length attribute name in the Information Window:
  • Note that in non-ASCII character sets, the length is the number of actual characters (some or all of which could be multi-byte) in the string, which may not match the number of bytes used to store the string.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the StringLengthCalculator on the FME Community.
