FME Transformers: 2025.2 BETA
Categories
Calculated Values
Strings
RandomNumberGenerator
Generates a uniformly distributed random number.
The random number is x, where Minimum Value <= x <= Maximum Value.
  • RandomNumberGenerator generates random numbers using the Tcl rand() function. The numbers generated by this function may not be considered truly random, because rand() requires an initial seed value, which determines the sequence of numbers that is generated. There are no more than 2^31 possible random number sequences, and these sequences repeat after 2^31 times. The same seed value, used repeatedly, generates the same numbers. Additionally, the sequence, by design, never produces the same number twice in a row.
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RandomNumberGenerator on the FME Community.
