FME Transformers: 2025.2 BETA
MSWordStyler
Prepares features for output to the Microsoft Word Writer by providing a convenient interface to set a variety of Microsoft Word format-specific attributes.
For more information regarding Microsoft Word styling, see the Microsoft Word Writer chapter in the FME Readers and Writers help. (In FME Workbench, select Help > FME Readers and Writers.)
Content Type |
This parameter specifies what kind of Microsoft Word content this feature will add into a document. Based on this parameter the rest of the parameter dialog will change. Format attribute set: msword_type |
In Microsoft Word, headings separate a document into collapsible sections. While editing a document in Microsoft Word, if you hover over heading text, an arrow will appear to the left of it allowing you to collapse its section.
Text |
This parameter controls what text the heading will show Format attribute set: msword_heading_text |
Heading Level |
Headings have different levels. Example: Heading 3 is a subheading of Heading 2, and if you collapse a heading of heading level 2, the entire document under it until the next heading level 2 or heading level 1 will be hidden, even if there are headings of level 3 or greater among the hidden text. Title is technically not a heading at all, but just some stylized text. Format attribute set: msword_heading_level |
Image Source |
Image Source has two options: From File and From Feature. If From File is selected, then the Image Filename parameter is used to select a file. If From Feature is selected, then the styled feature must have a raster geometry. Its raster geometry is written to the Microsoft Word document. Format attribute set: msword_image_source |
Image Filename |
Specifies the path to the desired image. To browse your file system for an image, click the browse button to the right of the text field. This parameter is only enabled if Image Source is From File Format attribute set: msword_image_filename |
Alignment |
Sets the image alignment. Format attribute set: msword_justification |
Width Units |
This in conjunction with Image Width specifies how large to scale the image. If Percentage of Page Width is chosen, then it means the percent of page within the left and right margins. It is possible to extend past the margins given a large enough width. Format attribute set: msword_measurement_units |
Image Width |
This in conjunction with Width Units specifies how large to scale the image. If Percentage of Page Width was chosen for Width Units, then 100 means the entire page width, while 1 means only one percent. Format attribute set: msword_image_width |
Text |
The text to be placed. Format attribute set: msword_bullet_text |
Indent Level |
How much indent to place left of the list item. In Microsoft Word, this correlates to starting a list, then pressing tab either zero, one, or two times. The positions of each indent level are customizable in Word if you have Ruler enabled through View on Microsoft Word’s ribbon. If the list is a numbered list, and the indent level changes, then the list item counter will reset to 1. Format attribute set: msword_bullet_indent |
List Type |
A list can either be Numbered, or Bulleted. A bulleted list always has a black dot to the left of each list item. A numbered list counts 1,2,3,… to the left of each list item. Format attribute set: msword_bullet_ordered |
Font |
The font name, size, and styling properties. To edit this parameter, click the browse button to the right of the text field. Format attribute set: msword_font_name Format attribute set: msword_font_size Format attribute set: msword_font_bold Format attribute set: msword_font_italic Format attribute set: msword_font_underline Format attribute set: msword_font_strikethrough |
Font Color |
The color of the text foreground for this list item. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. ![]() Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
* Color interpretation may vary in other contexts such as raster bands and palettes. Format attribute set: msword_font_color |
Number of Page Breaks |
This parameter specifies how many page breaks will be added to the document. Example: Three page breaks will skip to the next page, then add two empty pages, bringing about either 3 empty pages, or two empty pages and a partially empty page. Format attribute set: msword_break_count |
Style |
Several preset styles exist for the paragraph's typeface, font size, color, etc. Selecting Custom will enable the Font and Font Color parameters. Format attribute set: msword_paragraph_style |
Use Markdown |
Specifies to apply a simplistic markdown to the paragraph for bolding, italicizing, and underlining. If the font is set to bold, then the markdown will instead indicate where text should NOT be bolded. The same applies to italicizing and underlining. If a section of text is surrounded by doubles asterisks (**text**) then the section will be bolded. If a section of text is surrounded by double tildes (~~text~~) then the section will be italicized. If a section of text is surrounded by double underscores (__text__) then the section will be underlined. If either end of the section has any whitespace, the section will NOT be styled (** bold** has no effect). If a section is empty (****) there will be no effect. These effects can be used in conjunction (**~~bolded and italicized~~**). It’s important that the sections to not intersect each other (**~~a**~~ will not work properly.) The leftmost pattern matches will take precedence. (**left**right**) will bold left but not right. If an asterisk, tilde, or underscore is not part of a valid pattern match, that character will be left in the text to be placed. If any of those characters were part of a valid pattern match, they will not be visible in the text to be placed. Format attribute set: msword_use_markdown |
Text |
The text to place, in a separate paragraph. Format attribute set: msword_paragraph_text |
Font |
Font Color |
Alignment |
Sets the text justification Format attribute set: msword_justification |
Table Style |
These styles match what is shown in Microsoft Word’s ribbon under the design tab while editing a table. They modify the table’s appearance. Format attribute set: msword_table_style |
Width Units |
Specifies what units will be used when specifying column widths. If Percentage of Page Width is chosen, then it means the percent of page within the left and right margins. It is possible to extend past the margins given a large enough width. Format attribute set: msword_measurement_units |
Font |
Font Color |
The color of the text foreground for this item. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. ![]() Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
Table Data
Column Header |
The header text for the particular column. Format attribute set: msword_table_col_header |
Column Values |
The text value to place in a row under the particular column. Format attribute set: msword_table_col_value |
Column Width |
In conjunction with Width Units this sets the particular column’s width. Any positive number is valid here, or the word Stretch. Columns with the width Stretch will all share any leftover space after columns with specified sizes are given their space. If Percentage of Page Width was chosen for Width Units, then 100 means the entire page width, while 1 means only one percent. Format attribute set: msword_table_col_width |
Dependencies | None |
Aliases | |
History |
Search for all results about the MSWordStyler on the FME Community.
