FME Transformers: 2025.2 BETA
MQTTConnector
Connects to an MQTT broker to send and receive messages.
- Geoenrichment of data on an MQTT topic
- Aggregation of data from MQTT topics and other message streams
- Interoperability with Big Data analytics platforms
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from the broker.
- After a Send action, output features represent messages sent to the broker.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create an MQTT connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Broker URL, Broker Port |
Available when the credential source is Embedded. The broker URL and port allow FME to connect to the broker. |
Enable SSL/TLS |
Available when the credential source is Embedded. Whether to use a secure connection. Secure connections typically use port 8883, while insecure connections typically use port 1883. |
User Name, Password |
Available when the credential source is Embedded. The username and password to use when connecting to the broker. These are optional, allowing for anonymous access. |
CA Certificate |
Root CA certificate for broker. Optional. |
Client Certificate |
Certificate for client authentication. Optional. |
Client Private Key |
Private key for client authentication. Optional. |
Client ID |
The client ID uniquely identifies the FME client to the broker. Some brokers require pre-registration of client IDs, while others allow the client to register ad-hoc. |
Action |
The type of operation to perform. Choices are:
QoS Level |
The MQTT protocol allows a Quality of Service (QoS) level to be set. The following levels are available:
The QoS guarantees are achieved by performing differing levels of client-server handshake. As a result, higher QoS levels are expected to lower throughput. |
Receive Options
Topic |
The topic to receive from. Topics are usually hierarchical, and can contain the wildcard `#` and `+`. For more information about topic format, please see the following MQTT wiki page: https://github.com/mqtt/mqtt.github.io/wiki/topic_format |
Receive Mode |
Two message receiving options are available:
Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Send Options
Topic |
The topic to send to. Topics are usually hierarchical, and can contain the wildcard `#` and `+`. For more information about topic format, please see the following MQTT wiki page: https://github.com/mqtt/mqtt.github.io/wiki/topic_format |
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Retain Message |
Whether to set the message as the retained "last known good" value for the topic. Note that not all brokers support this setting. |
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
Dependencies | |
Aliases | |
History | Released FME 2019.0 |
Search for all results about the MQTTConnector on the FME Community.
