FME Transformers: 2025.2 BETA
Categories
Calculated Values
LengthToPointCalculator
Calculates the length of a feature from its start until the closest spot to a point, and adds it as a new attribute. The point coordinates are taken from attributes in the original feature.
The length is calculated along the feature up until the spot on the feature that is closest to the given point.
To calculate the length of the entire feature, use the LengthCalculator.
To calculate the distance from the start of the line to each vertex, use the MeasureGenerator.
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the LengthToPointCalculator on the FME Community.
