FME Transformers: 2025.2 BETA
IBMMQConnector
Connects to an IBM MQ 9.x Queue Manager to send or receive messages and publish or subscribe to topics.
- The IBMMQConnector supports Windows only.
- The IBMMQConnector connects to Queue Managers using the Client mode, so users must have an IBM MQ client installed locally. Bindings mode is not supported. For more details on installing a client, see Where to find downloadable installation images.
- The IBMMQConnector requires that the environment variable MQ_FILE_PATH be set. This should be done automatically during client installation.
The IBM MQ user used with the IBMMQConnector must have the following permissions. For more details on permissions, see SET AUTHREC (set authority records) on Multiplatforms.
QMGR: CONNECT, DSP, SETID
QUEUE: DSP, GET, INQ, PUT, SETID
TOPIC: PUB, SUB
Listing queues requires the following additional permissions.
SYSTEM.DEFAULT.MODEL.QUEUE: GET, DSP
There are possible restrictions on the default IBM MQ user named “app”. If running into authorization errors despite having the permissions above granted, try creating a different user.
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Send action, output features represent messages sent to a queue/topic.
- After a Receive action, output features represent messages received from a queue/topic.
- After a Count action, output features contain metadata for the number of messages in a queue.
On a Receive action, heartbeat features will be output through this port. Heartbeat features will have two output attributes:
- _heartbeat_id: Integer starting at 0. This is a unique identifier for each heartbeat feature output from this port.
- _heartbeat_counter: Integer starting at 0 that resets whenever the connector receives a new message and a new period of inactivity begins. This counter represents the number of consecutive heartbeat features.
See Heartbeat for more details.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note If a feature comes in to the IBMMQConnector already having a value for fme_rejection_code, this value will be removed.
Web Connection |
To create an IBM MQ web connection, click the Account drop-down box and select Add Web Connection.... The connection can then be managed via Tools > FME Options > Web Connections. |
Queue Manager |
The Queue Manager to connect to. |
Channel |
The MQ Channel to use. |
Use SSL |
Whether to use SSL or not. If checked, ensure that the Queue Manager is also configured to use SSL. |
Key Repository |
If Use SSL is checked, specify the key database file (.kdb). |
CipherSpec |
If Use SSL is checked, select a CipherSpec that is supported by the Queue Manager. |
Action |
The type of operation to perform. Choices are:
Defaults to Receive. |
Count Messages Options
Queue |
Select a Queue to count the number of pending messages. If Queue does not exist, the transformer will return a rejected feature. |
Send Options
Payload |
Message to send. |
Destination |
Send message to a:
Defaults to Queue. |
Queue |
If Destination is Queue, select a Queue to send message(s) to. |
Queue Message Descriptor |
Properties to apply to message(s) when Destination is Queue:
For more details on message descriptor properties, see: MQMD - Message descriptor. |
Topic String |
If Destination is Topic, specify the topic string that identifies the Topic to send message(s) for. This is a character string that must be broken up into ‘/’ delimited parts. See Topic strings for details. |
Topic Message Descriptor |
Properties to apply to message(s) when Destination is Topic:
For more details on message descriptor properties, see: MQMD - Message descriptor |
Maximum Message Length (MB) |
The maximum length of a message that can be transmitted on the specified Channel. Maximum must be between 4 and 100. Default is 4 MB. Note that when adjusting the Maximum Message Length, users may also need to update the queue, queue manager, and channel configurations via MQSC commands or the MQ Console. |
Receive Options
Source |
Get message from a:
Queue |
If Source is Queue, select a Queue to receive message(s) from. |
Topic String |
If Source is Topic, specify the topic string that is being subscribed to. This is a character string that must be broken up into ‘/’ delimited parts. See Topic strings for details. |
Subscription Name |
If Source is Topic, specify the name of the Subscription to receive message(s) from. If the specified Subscription does not exist, a new Subscription will be created for Topic String. |
Durable Subscription |
If Source is Topic, determine whether a Subscription is durable or not. Defaults to Yes. |
Receive Mode |
Two message receiving options are available:
Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Get JMS Headers |
If Source is Queue, determine whether JMS (Java Message Service) headers are kept or discarded. Default to Yes. |
The maximum length of a message that can be transmitted on the specified Channel. Maximum must be between 4 and 100. Default is 4 MB. Note that when adjusting the Maximum Message Length, users may also need to update the queue, queue manager, and channel configurations via MQSC commands or the MQ Console. For subscriptions, users may need to update the underlying queue configuration. |
Heartbeat
When Action is set to Receive, a heartbeat feature is output through the Heartbeat port after a period of inactivity. The length of this period is determined by the following parameters:
Interval |
The period of inactivity before a heartbeat feature is emitted, in units specified by the Time Unit parameter. Defaults to 1. |
Time Unit |
The unit for Interval.
Defaults to Hours. |
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
Dependencies | |
Aliases | |
History |
Search for all results about the IBMMQConnector on the FME Community.
