FME Transformers: 2025.2 BETA
Categories
Strings
Related Transformers
CharacterCodeExtractor
CharacterCodeReplacer
Sets the result attribute to the character whose numeric code was contained in the source code attribute (or the entered integer).
This can be used when the numeric Unicode code of any character (from Basic Multilingual Plane) is available, but the actual Unicode character is desired. For example, if the source attribute had the value 65487 (U+FFCF), a half-width Hangul letter ᅬ character would be placed in the resulting string.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases CharacterEncoder
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the CharacterCodeReplacer on the FME Community.
