FME Transformers: 2025.2 BETA
ArcGISBranchVersionManager
Connects to an ArcGIS Enterprise Version Management Server to manage a feature service's branch versions.
Listing, posting, or reconciling branches on a versioned feature service
The ArcGISBranchVersionManager connects to an ArcGIS Enterprise Version Management Server to perform various tasks:
Action |
Task |
List |
List branches with metadata. |
Post |
Post changes to a branch to the default branch and identify any conflicts. |
Reconcile |
Reconcile a branch with the default branch and identify any conflicts. |
Specifying Service URLs
Where the URL of a version management server for a feature service is specified, it can take one of these forms:
- the URL to the version management server, ending in /VersionManagementServer
- the URL to the feature server itself, ending in /FeatureServer
- the URL to a feature or layer on a feature server, as in https://<feature_service_url>/<layer_id>/<object_id_of_feature>
If it is not already known, the service URL of a feature service can be discovered by using the ArcGIS Feature Service reader, which returns the feature URL in the format attribute arcgisfeatureservice_feature_url.
Features with added attributes, as specified in parameters and according to Action.
Input features are output here unmodified, in addition to any other output locations (Output or <Rejected>).
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Connection |
Select or create a Web Connection, connecting to the appropriate Web Service:
Action |
The type of operation to perform. Choices include:
Branch Version
Service URL |
Specify the URL of the version management server for the feature service. |
Action
Include Hidden Branches |
Select an option for handling hidden branches:
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Branch Version
Service URL |
Version Name |
Specify the name of the branch version to post to. |
Action
If Conflicts Detected |
Select an option for handling conflicts:
Note that even if Continue is selected, the post may still fail if the conflicting branch was not already reconciled. |
Output Attributes
Attributes to Add |
Branch Version
Service URL |
Version Name |
Specify the name of the branch version to reconcile. |
Action
Output Attributes
Attributes to Add |
Dependencies | Esri Access |
Aliases | |
History |
Search for all results about the ArcGISBranchVersionManager on the FME Community.
